Saltar al contenido principal
Power Mac G4 Quicksilver Optical Drive Disassembly
Qué necesitas
  1. Power Mac G4 Quicksilver Optical Drive Disassembly, Opening the case: paso 1, imagen 1 de 1
    • The handle to open your computer is located on top of the right side panel.
  2. Power Mac G4 Quicksilver Optical Drive Disassembly: paso 2, imagen 1 de 2 Power Mac G4 Quicksilver Optical Drive Disassembly: paso 2, imagen 2 de 2
    • Grab the circular handle and pull outward.
  3. Power Mac G4 Quicksilver Optical Drive Disassembly: paso 3, imagen 1 de 1
    • Your computer is now open and ready for repair.
  4. Power Mac G4 Quicksilver Optical Drive Disassembly, Power Mac G4 Quicksilver Optical Drive Disassembly: paso 4, imagen 1 de 1
    • The optical drive is in the top left corner of the case.
  5. Power Mac G4 Quicksilver Optical Drive Disassembly: paso 5, imagen 1 de 2 Power Mac G4 Quicksilver Optical Drive Disassembly: paso 5, imagen 2 de 2
    • There are four screws to be removed.
    • The first screw can be seen in the first picture.
    • The remaining three screws can be seen in the second picture.
  6. Power Mac G4 Quicksilver Optical Drive Disassembly: paso 6, imagen 1 de 1
    • Remove the optical drive by pulling the drive away from the front of the computer and out.
  7. Power Mac G4 Quicksilver Optical Drive Disassembly: paso 7, imagen 1 de 1
    • Detach the two cables attached to the back of the drive.
    • The flat ribbon cable can be detached by pulling the silver tab. The multicolored cable can be removed by grasping the plastic connector on either side and pulling with substantial force.
Conclusión
7 personas más completaron esta guía.
Jacob Garcia
Miembro Desde 01/28/10
621 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 14-41, Regan Winter 2010 Miembro de Cal Poly, Team 14-41, Regan Winter 2010
CPSU-REGAN-W10S14G41
4 Miembros
17 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 5,659
