Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Archivada
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Archivada
Introducción
This is meant to be a private prereq guide.
Partes
No se especificaron partes.
  1. The hard drive is located in the back right corner of the case.
    • The hard drive is located in the back right corner of the case.
  2. Remove the flat ribbon cable by pulling with substantial force.
    • Remove the flat ribbon cable by pulling with substantial force.
  3. Remove the screw holding the hard drive to the computer.
    • Remove the screw holding the hard drive to the computer.
  4. Pull the drive up and out of the computer.
    • Pull the drive up and out of the computer.
  5. Remove the multicolored cable by grasping the plastic connector on either side and pulling with substantial force.
    • Remove the multicolored cable by grasping the plastic connector on either side and pulling with substantial force.
Conclusión
10 personas más completaron esta guía.
Ryan Bylard
Miembro Desde 20/01/10
1,280 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 14-41, Regan Winter 2010 Miembro de Cal Poly, Team 14-41, Regan Winter 2010
CPSU-REGAN-W10S14G41
4 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 7
Todo El Tiempo: 7,273
