Saltar al contenido principal
Power Mac G4 MDD Hard Drives Replacement
Qué necesitas
  1. Power Mac G4 MDD Hard Drives Replacement, Case: paso 1, imagen 1 de 2 Power Mac G4 MDD Hard Drives Replacement, Case: paso 1, imagen 2 de 2
    • The Power Mac G4 MDD: the last, and the fastest G4-based Mac. This computer boasted up to a Dual 1.42GHz PowerPC G4 CPU (though I have a single 1.25GHz).
    • Two USB 1.1 Ports
    • Assorted Audio
    • Video (ADC & DVI)
    • Networking (RJ-45 Ethernet/56k Modem)
    • Some later model MDD's (such as the dual 1.42GHz) Have a FireWire 800 Port Here:
  2. Power Mac G4 MDD Hard Drives Replacement: paso 2, imagen 1 de 3 Power Mac G4 MDD Hard Drives Replacement: paso 2, imagen 2 de 3 Power Mac G4 MDD Hard Drives Replacement: paso 2, imagen 3 de 3
    • Unplug the computer.
    • Unplug the power supply and all external connections from the computer.
    • Pull on the side lever and lower the side of the case.
  3. Power Mac G4 MDD Hard Drives Replacement, Hard Drives: paso 3, imagen 1 de 1
    • The hard drive cages are located here.
  4. Power Mac G4 MDD Hard Drives Replacement: paso 4, imagen 1 de 3 Power Mac G4 MDD Hard Drives Replacement: paso 4, imagen 2 de 3 Power Mac G4 MDD Hard Drives Replacement: paso 4, imagen 3 de 3
    • Cage 1
    • Start by removing this screw.
    • Remove the ATA-66/ IDE ribbon cable from the motherboard.
  5. Power Mac G4 MDD Hard Drives Replacement: paso 5, imagen 1 de 2 Power Mac G4 MDD Hard Drives Replacement: paso 5, imagen 2 de 2
    • Now, remove the power connection from the drives.
  6. Power Mac G4 MDD Hard Drives Replacement: paso 6, imagen 1 de 3 Power Mac G4 MDD Hard Drives Replacement: paso 6, imagen 2 de 3 Power Mac G4 MDD Hard Drives Replacement: paso 6, imagen 3 de 3
    • Push this tab down, and pull the cage toward you.
    • Now, you can set cage 1 aside.
  7. Power Mac G4 MDD Hard Drives Replacement: paso 7, imagen 1 de 2 Power Mac G4 MDD Hard Drives Replacement: paso 7, imagen 2 de 2
    • Cage 2:
    • Remove this Phillips screw:
    • Disconnect this IDE ribbon cable from the logic board.
  8. Power Mac G4 MDD Hard Drives Replacement: paso 8, imagen 1 de 2 Power Mac G4 MDD Hard Drives Replacement: paso 8, imagen 2 de 2
    • It's likely that there is a cable clip holding the ribbon cable to the case.
    • To remove it, push the end, and it should pop up.
  9. Power Mac G4 MDD Hard Drives Replacement: paso 9, imagen 1 de 3 Power Mac G4 MDD Hard Drives Replacement: paso 9, imagen 2 de 3 Power Mac G4 MDD Hard Drives Replacement: paso 9, imagen 3 de 3
    • With the ribbon cable clip free, pull this tab towards you, slide the cage up until it hits the platform under the power supply, and pull it away.
    • Now, set the cage on top of the CPU, and remove the power connectors.
  10. Power Mac G4 MDD Hard Drives Replacement: paso 10, imagen 1 de 2 Power Mac G4 MDD Hard Drives Replacement: paso 10, imagen 2 de 2
    • Once the cables are free, set the drive cage aside.
    • To remove the hard drives from the cages, remove the four screws on the sides of the cage that are connected to the drives, then slide the drives out.
    • The two cages are cross compatible and can be put in either location.
    • The MDD does not have a 128GB drive limit like older Macs. My MDD has 3 drives (a 400GB Hitatchi Deskstar, 40GB Seagate Barracuda 7200.7, and a 30GB Quantum Fireball LCT).
    • Note the ID jumpers on the two drive set. One is set to Master, the other to slave. A single drive can be set to Cable Select.
Conclusión
33 personas más completaron esta guía.
Chris Green
Miembro Desde 10/11/09
37,014 Reputación
49 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
322 Miembros
2,540 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 29
Ultimos 30 días: 113
Todo El Tiempo: 47,081
