Saltar al contenido principal
Power Mac G4 M5183 Processor Replacement
Qué necesitas
  1. Power Mac G4 M5183 Processor Replacement, Opening PowerMac G4 M5183 Case: paso 1, imagen 1 de 2 Power Mac G4 M5183 Processor Replacement, Opening PowerMac G4 M5183 Case: paso 1, imagen 2 de 2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Power Mac G4 M5183 Processor Replacement, Heat Sink: paso 2, imagen 1 de 2 Power Mac G4 M5183 Processor Replacement, Heat Sink: paso 2, imagen 2 de 2
    • Use the spudger to pry the clips horizontally off of the heat sink.
    • Fully remove the clips by lifting upwards.
  3. Power Mac G4 M5183 Processor Replacement: paso 3, imagen 1 de 1
    • Remove the heat sink by pulling upwards, off of the logic board.
  4. Power Mac G4 M5183 Processor Replacement, Processor: paso 4, imagen 1 de 2 Power Mac G4 M5183 Processor Replacement, Processor: paso 4, imagen 2 de 2
    • Remove the 3 screws attaching the processor to the logic board using the Phillips #2 screwdriver.
    • Remove processor by pulling vertically upwards.
Linea de Meta
13 personas más completaron esta guía.
Justin Petrilli
Miembro Desde 01/21/10
3,114 Reputación
11 Guías creadas
Equipo
Cal Poly, Team 13-24, Maness Winter 2010 Miembro de Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 Miembros
25 Guías creadas
2 comentarios
anyone still sell the replacement processor?
Joseph Cole - Contestar
Anyone who has upgraded their CPU’s manage to flash from MacPro1,1 to MacPro2,1? And If so How?
Michael Inman - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 24
Todo El Tiempo: 12,139
