Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
How to remove the processor from the logic board.
  1. Pull on outer latch. Lower door until it is level with your work surface.
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Use the spudger to pry the clips horizontally off of the heat sink. Fully remove the clips by lifting upwards.
    • Use the spudger to pry the clips horizontally off of the heat sink.
    • Fully remove the clips by lifting upwards.
  3. Remove the heat sink by pulling upwards, off of the logic board.
    • Remove the heat sink by pulling upwards, off of the logic board.
  4. Remove the 3 screws attaching the processor to the logic board using the Phillips #2 screwdriver. Remove processor by pulling vertically upwards.
    • Remove the 3 screws attaching the processor to the logic board using the Phillips #2 screwdriver.
    • Remove processor by pulling vertically upwards.
Linea de Meta
13 personas más completaron esta guía.
Justin Petrilli
Miembro Desde 21/01/10
2,940 Reputación
11 Guías creadas
Equipo
Cal Poly, Team 13-24, Maness Winter 2010 Miembro de Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 Miembros
25 Guías creadas
anyone still sell the replacement processor?
Joseph Cole - Contestar
Anyone who has upgraded their CPU’s manage to flash from MacPro1,1 to MacPro2,1? And If so How?
Michael Inman - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 17
Todo El Tiempo: 11,180
