Saltar al contenido principal
Power Mac G4 M5183 Heat Sink Replacement
Qué necesitas
  1. Power Mac G4 M5183 Heat Sink Replacement, Opening PowerMac G4 M5183 Case: paso 1, imagen 1 de 2 Power Mac G4 M5183 Heat Sink Replacement, Opening PowerMac G4 M5183 Case: paso 1, imagen 2 de 2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Power Mac G4 M5183 Heat Sink Replacement, Heat Sink: paso 2, imagen 1 de 2 Power Mac G4 M5183 Heat Sink Replacement, Heat Sink: paso 2, imagen 2 de 2
    • Use the spudger to pry the clips horizontally off of the heat sink.
    • Fully remove the clips by lifting upwards.
  3. Power Mac G4 M5183 Heat Sink Replacement: paso 3, imagen 1 de 1
    • Remove the heat sink by pulling upwards, off of the logic board.
Linea de Meta
6 personas más completaron esta guía.
Justin Petrilli
Miembro Desde 01/21/10
3,114 Reputación
11 Guías creadas
Equipo
Cal Poly, Team 13-24, Maness Winter 2010 Miembro de Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 Miembros
25 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 5,873
