Saltar al contenido principal
Power Mac G4 Cube Optical Drive Replacement
Qué necesitas
  1. Power Mac G4 Cube Optical Drive Replacement, Outer Case: paso 1, imagen 1 de 3 Power Mac G4 Cube Optical Drive Replacement, Outer Case: paso 1, imagen 2 de 3 Power Mac G4 Cube Optical Drive Replacement, Outer Case: paso 1, imagen 3 de 3
    • Release the back handle of the PowerMac. Slowly pull out the cube by holding the end of the handle. Watch for any parts that may become entangled with the outer case.
    • Push back the handle after you have taken the core out of the case.
  2. Power Mac G4 Cube Optical Drive Replacement: paso 2, imagen 1 de 2 Power Mac G4 Cube Optical Drive Replacement: paso 2, imagen 2 de 2
    • Place the cube upside down and remove the four T10 Torx screws on the front plate. Then remove the two screws on each side.
  3. Power Mac G4 Cube Optical Drive Replacement: paso 3, imagen 1 de 1
    • Slowly lift the plate off the cube and disconnect the power cord.
  4. Power Mac G4 Cube Optical Drive Replacement: paso 4, imagen 1 de 1
    • Remove the four pillars from each corner.
    • The pillars should come out fairly easily.
  5. Power Mac G4 Cube Optical Drive Replacement, Optical Drive: paso 5, imagen 1 de 1
    • Remove a total of four screws on the sides of the optical drive.
  6. Power Mac G4 Cube Optical Drive Replacement: paso 6, imagen 1 de 1
    • Slowly lift up the optical drive and remove the IDE cable.
    • Remove the power cable.
Conclusión
11 personas más completaron esta guía.
Ryan Chun
Miembro Desde 06/24/10
1,076 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 2-7, Johann Summer 2010 Miembro de Cal Poly, Team 2-7, Johann Summer 2010
CPSU-JOHANN-R10S2G7
5 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 43
Todo El Tiempo: 10,229
