Saltar al contenido principal
Power Mac G4 Cube Airport Card Replacement
  1. Power Mac G4 Cube Airport Card Replacement, Remove Cube Core: paso 1, imagen 1 de 3 Power Mac G4 Cube Airport Card Replacement, Remove Cube Core: paso 1, imagen 2 de 3 Power Mac G4 Cube Airport Card Replacement, Remove Cube Core: paso 1, imagen 3 de 3
    • Release the handle at the bottom of the Power Mac G4 Cube by pushing it down. Slowly pull out the cube by holding the end of the handle.
    • Watch for any parts that may become entangled with the outer case.
    • Push back the handle after you have taken the core out of the case.
  2. Power Mac G4 Cube Airport Card Replacement, Accessing AirPort Card: paso 2, imagen 1 de 2 Power Mac G4 Cube Airport Card Replacement, Accessing AirPort Card: paso 2, imagen 2 de 2
    • Pull outwards on the antenna cable.
    • The cable should pop out of the card without much force.
    • Pull on the clear tab outwards to remove the existing AirPort card
    • Slide in the new AirPort card.
    • Reconnect the antenna cable.
Conclusión
8 personas más completaron esta guía.
Ryan Chun
Miembro Desde 06/24/10
1,076 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 2-7, Johann Summer 2010 Miembro de Cal Poly, Team 2-7, Johann Summer 2010
CPSU-JOHANN-R10S2G7
5 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 18
Todo El Tiempo: 9,900
