Saltar al contenido principal
Poukaran ZRW-TD-SRK2 LED Replacement
Qué necesitas
  1. Poukaran ZRW-TD-SRK2 LED Replacement, LED Strip: paso 1, imagen 1 de 3 Poukaran ZRW-TD-SRK2 LED Replacement, LED Strip: paso 1, imagen 2 de 3 Poukaran ZRW-TD-SRK2 LED Replacement, LED Strip: paso 1, imagen 3 de 3
    • Use a Phillips #1 screwdriver to remove the 7.5mm screws securing the front of the lamp's outer casing or lid.
  2. Poukaran ZRW-TD-SRK2 LED Replacement: paso 2, imagen 1 de 3 Poukaran ZRW-TD-SRK2 LED Replacement: paso 2, imagen 2 de 3 Poukaran ZRW-TD-SRK2 LED Replacement: paso 2, imagen 3 de 3
    • Use a Phillips #1 screwdriver to remove the last two 7.5 mm screws securing the back of the lamp's outer casing or lid.
  3. Poukaran ZRW-TD-SRK2 LED Replacement: paso 3, imagen 1 de 2 Poukaran ZRW-TD-SRK2 LED Replacement: paso 3, imagen 2 de 2
    • Once the lid is off, locate and remove the top plate covering the internal components of the lamp.
  4. Poukaran ZRW-TD-SRK2 LED Replacement: paso 4, imagen 1 de 3 Poukaran ZRW-TD-SRK2 LED Replacement: paso 4, imagen 2 de 3 Poukaran ZRW-TD-SRK2 LED Replacement: paso 4, imagen 3 de 3
    • Use a soldering iron to carefully desolder the wires connecting the faulty LED strips. Ensure you're desoldering the correct connections. Solder the new LED strips in place, connecting the wires securely to the designated points on the lamp's circuit board.
    • Exercise caution when lifting the plate that holds the LEDs, as there is a risk of accidentally pulling out the wires.
Conclusión
To reassemble your device, follow these instructions in reverse order. Ensure each component is securely in place and all connections are properly aligned.
andrez oceguera
Miembro Desde 08/23/23
109 Reputación
1 Guía escrita
Equipo
CSU Los Angeles, Team 2-1, Briggs Fall 2023 Miembro de CSU Los Angeles, Team 2-1, Briggs Fall 2023
CSULA-BRIGGS-F23S2G1
6 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 17
Todo El Tiempo: 63
