Saltar al contenido principal
Porter-Cable PCE211 Brush Replacement
Qué necesitas
  1. Porter-Cable PCE211 Brush Replacement, Rear Housing: paso 1, imagen 1 de 2 Porter-Cable PCE211 Brush Replacement, Rear Housing: paso 1, imagen 2 de 2
    • Remove the four 6 mm screws using a Phillips #2 screwdriver.
    • The screws are tight so you will need to use a bit of arm strength.
  2. Porter-Cable PCE211 Brush Replacement: paso 2, imagen 1 de 2 Porter-Cable PCE211 Brush Replacement: paso 2, imagen 2 de 2
    • Pull the rear housing off the back of the impact wrench.
    • Be careful when removing the rear case that loose parts don't get damaged.
  3. Porter-Cable PCE211 Brush Replacement, Brush: paso 3, imagen 1 de 2 Porter-Cable PCE211 Brush Replacement, Brush: paso 3, imagen 2 de 2
    • Remove the brushes connected to the red and black cords.
    • They are not secured so they made drop out naturally.
  4. Porter-Cable PCE211 Brush Replacement: paso 4, imagen 1 de 3 Porter-Cable PCE211 Brush Replacement: paso 4, imagen 2 de 3 Porter-Cable PCE211 Brush Replacement: paso 4, imagen 3 de 3
    • Gently pull each brush off the corresponding cable to avoid damaging the cables.
Conclusión
Layla Berry
Miembro Desde 09/19/22
678 Reputación
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 18
Todo El Tiempo: 256
