Saltar al contenido principal
Porter-Cable PCE211 Anvil Replacement
Qué necesitas
  1. Porter-Cable PCE211 Anvil Replacement, Gearcase: paso 1, imagen 1 de 2 Porter-Cable PCE211 Anvil Replacement, Gearcase: paso 1, imagen 2 de 2
    • Using the Hex Security SAE 7/32", remove the four 10 mm socket screws at the base of the gearcase.
  2. Porter-Cable PCE211 Anvil Replacement: paso 2, imagen 1 de 3 Porter-Cable PCE211 Anvil Replacement: paso 2, imagen 2 de 3 Porter-Cable PCE211 Anvil Replacement: paso 2, imagen 3 de 3
    • Grip the body of the impact wrench with one hand and the gearcase in the other and firmly pull to remove it.
    • Be careful about any loose parts when removing the head.
  3. Porter-Cable PCE211 Anvil Replacement, Anvil: paso 3, imagen 1 de 3 Porter-Cable PCE211 Anvil Replacement, Anvil: paso 3, imagen 2 de 3 Porter-Cable PCE211 Anvil Replacement, Anvil: paso 3, imagen 3 de 3
    • Firmly pull the to remove drill bit holder also known as the anvil.
    • Before replacing the anvil, lubricate the base for the best performance.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 125
