Saltar al contenido principal
Porter-Cable PC60TAG Power Cord Replacement
Qué necesitas
  1. Porter-Cable PC60TAG Power Cord Replacement, Power Cord: paso 1, imagen 1 de 1
    • Using the Phillips #2 screwdriver, remove the 3/4" Phillips head screw on the back cover.
    • Unplug the grinder before disassembling.
  2. Porter-Cable PC60TAG Power Cord Replacement: paso 2, imagen 1 de 1
    • Holding the front of the device, carefully slide the back cover over the cord.
  3. Porter-Cable PC60TAG Power Cord Replacement: paso 3, imagen 1 de 1
    • Using the Phillips #2 screwdriver, remove the two 1/2" Phillips head screws securing the cord grip.
  4. Porter-Cable PC60TAG Power Cord Replacement: paso 4, imagen 1 de 1
    • Using the Phillips #2 screwdriver, loosen, but do not remove, the two terminal screws securing the black and white wires from the power cord.
  5. Porter-Cable PC60TAG Power Cord Replacement: paso 5, imagen 1 de 1
    • Careful remove each wire from the power cord from underneath the terminals.
Conclusión
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 440
