Saltar al contenido principal
Porter-Cable PC60TAG Pinion Gear Replacement
Qué necesitas
  1. Porter-Cable PC60TAG Pinion Gear Replacement, Pinion Gear: paso 1, imagen 1 de 1
    • Using the Phillips #2 screwdriver, remove the 3/4" screw on the back cover.
  2. Porter-Cable PC60TAG Pinion Gear Replacement: paso 2, imagen 1 de 1
    • Holding the front of the device, carefully slide the back cover over the cord.
  3. Porter-Cable PC60TAG Pinion Gear Replacement: paso 3, imagen 1 de 1
    • Using the Phillips #2 screwdriver, remove the 1/2" screw holding on the motor brush arm. Repeat on the other side.
  4. Porter-Cable PC60TAG Pinion Gear Replacement: paso 4, imagen 1 de 1
    • Carefully pull the motor brush arm away from the other device, you can leave the wire connected to device. Repeat on the other side.
  5. Porter-Cable PC60TAG Pinion Gear Replacement: paso 5, imagen 1 de 1
    • Using the Phillips #2 screwdriver, remove the 1 inch black retainer screw.
  6. Porter-Cable PC60TAG Pinion Gear Replacement: paso 6, imagen 1 de 1
    • Using the Phillips #2 screwdriver, remove the four, 1/2" Phillips screws around the head gear.
  7. Porter-Cable PC60TAG Pinion Gear Replacement: paso 7, imagen 1 de 1
    • Carefully pull the head gear away from the device, and set aside.
  8. Porter-Cable PC60TAG Pinion Gear Replacement: paso 8, imagen 1 de 1
    • Using the Phillips #2 screwdriver, remove the two 1/2" Phillips screws holding the head to the body on the bottom side of the grinder.
  9. Porter-Cable PC60TAG Pinion Gear Replacement: paso 9, imagen 1 de 1
    • Using the Phillips #2 screwdriver, remove the other two 1/2" Phillips screws holding the head to the body on the top side of the grinder.
  10. Porter-Cable PC60TAG Pinion Gear Replacement: paso 10, imagen 1 de 1
    • Holding the head of the device, carefully pull the motor assembly out of the body of the device.
  11. Porter-Cable PC60TAG Pinion Gear Replacement: paso 11, imagen 1 de 1
    • Using a 9/16" wrench, loosen the spindle nut inside the head, from the motor assembly.
  12. Porter-Cable PC60TAG Pinion Gear Replacement: paso 12, imagen 1 de 1
    • Pull the motor assembly away from the head, and set aside
  13. Porter-Cable PC60TAG Pinion Gear Replacement: paso 13, imagen 1 de 1
    • Using a pair of needle nose pliers, remove the pinion gear from the head.
Conclusión
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 655
