Saltar al contenido principal
Porter-Cable PC60TAG Motor Brush Replacement
Qué necesitas
  1. Porter-Cable PC60TAG Motor Brush Replacement, Motor Brush: paso 1, imagen 1 de 1
    • Using the Phillips #2 screwdriver, remove the 3/4" screw on the back cover.
    • Unplug the grinder before disassembling.
  2. Porter-Cable PC60TAG Motor Brush Replacement: paso 2, imagen 1 de 1
    • Holding the front of the device, carefully slide the back cover over the cord.
  3. Porter-Cable PC60TAG Motor Brush Replacement: paso 3, imagen 1 de 1
    • Using the Phillips #2 screwdriver, remove the 1/2" screw holding on the motor brush arm.
  4. Porter-Cable PC60TAG Motor Brush Replacement: paso 4, imagen 1 de 1
    • Carefully pull the motor brush arm away from the other device.
  5. Porter-Cable PC60TAG Motor Brush Replacement: paso 5, imagen 1 de 1
    • Using the spudger, carefully lift the spring on the motor brush arm off of the motor brush and gently pull it to the side of the motor bush arm.
    • Be careful not to over bend the spring, as this could damage the spring and require replacement.
  6. Porter-Cable PC60TAG Motor Brush Replacement: paso 6, imagen 1 de 2 Porter-Cable PC60TAG Motor Brush Replacement: paso 6, imagen 2 de 2
    • Using the spudger, gently push the motor brush out of the arm.
  7. Porter-Cable PC60TAG Motor Brush Replacement: paso 7, imagen 1 de 1
    • Using a pair of needle nose pliers, gently pull the motor brush terminal off of the motor brush arm.
    • Repeat steps 3-7 on the other side of the device.
Conclusión
Una persona más ha completado esta guía.
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 829
