Saltar al contenido principal
Porter-Cable 382 Sander Pad Replacement
Qué necesitas
  1. Porter-Cable 382 Sander Pad Replacement, Sander Pad: paso 1, imagen 1 de 1
    • When changing the sander pad, be sure to rotate the sander upside down so the pad and three highlighted screws are facing upward toward you.
    • Once the sander is upside down begin by removing your old sandpaper.
    • Once the sandpaper is removed locate the three screws on your sander pad.
  2. Porter-Cable 382 Sander Pad Replacement: paso 2, imagen 1 de 1
    • Remove the three, (star bolt) screws with the iFixit screw driver with a "T20" head. Be sure to hold the pad of the sander as it will rotate as you try to loosen the screws.
    • Once the screws are removed pull upward toward you and the sander pad will come apart from the device.
Conclusión
Una persona más ha completado esta guía.
Nick O'Sadcia
Miembro Desde 03/11/16
421 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 1,803
