Saltar al contenido principal
Porter-Cable 382 On/ Off Switch Replacement
Qué necesitas
  1. Porter-Cable 382 On/ Off Switch Replacement, On/ Off Switch: paso 1, imagen 1 de 2 Porter-Cable 382 On/ Off Switch Replacement, On/ Off Switch: paso 1, imagen 2 de 2
    • First, locate the three screws on the top of the sander.
    • Using a screw driver with a size T20 star bit, unscrew the screws by turning them to the left.
  2. Porter-Cable 382 On/ Off Switch Replacement: paso 2, imagen 1 de 2 Porter-Cable 382 On/ Off Switch Replacement: paso 2, imagen 2 de 2
    • Locate your on off switch and in order to remove it you must slide it out of its slot.
    • This shouldnt require any special tools, just wiggle the switch up and out.
    • Make sure this is done carefully, the switch is attached to two wires that may break if they are pulled on too hard.
  3. Porter-Cable 382 On/ Off Switch Replacement: paso 3, imagen 1 de 1
    • Using a spudger such as the one shown, carefully pry open the connectors as shown just enough to slide the prongs of the switch out.
    • Once both prongs are open, the on-off switch can be removed freely and replaced with a new switch.
Conclusión
Nick O'Sadcia
Miembro Desde 03/11/16
421 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 241
