Saltar al contenido principal
Porter-Cable 382 Dust Seal | Dust Break Replacement
Qué necesitas
  1. Porter-Cable 382 Dust Seal | Dust Break Replacement, Sander Pad: paso 1, imagen 1 de 1
    • When changing the sander pad, be sure to rotate the sander upside down so the pad and three highlighted screws are facing upward toward you.
    • Once the sander is upside down begin by removing your old sandpaper.
    • Once the sandpaper is removed locate the three screws on your sander pad.
  2. Porter-Cable 382 Dust Seal | Dust Break Replacement: paso 2, imagen 1 de 1
    • Remove the three, (star bolt) screws with the iFixit screw driver with a "T20" head. Be sure to hold the pad of the sander as it will rotate as you try to loosen the screws.
    • Once the screws are removed pull upward toward you and the sander pad will come apart from the device.
  3. Porter-Cable 382 Dust Seal | Dust Break Replacement, Dust Seal/ Break: paso 3, imagen 1 de 1
    • Once the sander pad is removed and the sander is exposed locate the white plastic like circular piece surrounding the outside of the sander.
  4. Porter-Cable 382 Dust Seal | Dust Break Replacement: paso 4, imagen 1 de 2 Porter-Cable 382 Dust Seal | Dust Break Replacement: paso 4, imagen 2 de 2
    • Once you have located the plastic white ring pull up its outer edge as shown. The lip on the inside will bend and be freed from its secured placement.
    • To reassemble, you will have to line up the protruding square with the key slot as shown otherwise your dust seal/ brake will not go back in.
Conclusión
jpfoxracing9
Miembro Desde 03/11/16
189 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 561
