Saltar al contenido principal
Porter Cable 690LR Base Panel Replacement
Qué necesitas
  1. Porter Cable 690LR Base Panel Replacement, Base: paso 1, imagen 1 de 2 Porter Cable 690LR Base Panel Replacement, Base: paso 1, imagen 2 de 2
    • Undo the black latch located on the base of the router by pulling upwards from underneath it.
  2. Porter Cable 690LR Base Panel Replacement: paso 2, imagen 1 de 2 Porter Cable 690LR Base Panel Replacement: paso 2, imagen 2 de 2
    • Twist the base off the router.
    • You may need to jiggle the base of the router slightly.
  3. Porter Cable 690LR Base Panel Replacement, Base Panel: paso 3, imagen 1 de 2 Porter Cable 690LR Base Panel Replacement, Base Panel: paso 3, imagen 2 de 2
    • Orient the base so the black circular plate is facing you. Locate the three silver screw heads.
    • Use a flathead screwdriver to take off the three 10 mm screws.
Conclusión
Una persona más ha completado esta guía.
Emma Stine
Miembro Desde 10/06/16
273 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 20-7, Livingston Fall 2016 Miembro de Cal Poly, Team 20-7, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G7
4 Miembros
6 Guías creadas
Un comentario
Aynı ürünü kullanıyorum..! Son birkaç yıldır Porter Cable ürünlerini kullanıyorum
Ancak bunu bu siteden satın aldım - https://www.raptorsupplies.com/b/porter-...
Omer Polat - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 207
