Saltar al contenido principal
Pop-Up Assembly Stopper Piece Replacement
Qué necesitas
  1. Pop-Up Assembly Stopper Piece Replacement, Pop-Up Stopper Piece: paso 1, imagen 1 de 2 Pop-Up Assembly Stopper Piece Replacement, Pop-Up Stopper Piece: paso 1, imagen 2 de 2
    • Place bucket directly under the sink below the pop-up assembly. Excess water may leak
    • The pivot rod that is inserted within a hole in the pop-up extension bar. Move the pop-up extension bar away from the pivot rod.
  2. Pop-Up Assembly Stopper Piece Replacement: paso 2, imagen 1 de 1
    • Disconnect the pivot rod from the center pop-up extension.
  3. Pop-Up Assembly Stopper Piece Replacement: paso 3, imagen 1 de 2 Pop-Up Assembly Stopper Piece Replacement: paso 3, imagen 2 de 2
    • Lift up the center pop-up rod on the faucet until it is detached. The extension rod will pull up with it.
  4. Pop-Up Assembly Stopper Piece Replacement: paso 4, imagen 1 de 3 Pop-Up Assembly Stopper Piece Replacement: paso 4, imagen 2 de 3 Pop-Up Assembly Stopper Piece Replacement: paso 4, imagen 3 de 3
    • Below the sink is the pivot nut. Turn the pivot nut counterclockwise until it is completely loose and remove from the pivot rod.
  5. Pop-Up Assembly Stopper Piece Replacement: paso 5, imagen 1 de 2 Pop-Up Assembly Stopper Piece Replacement: paso 5, imagen 2 de 2
    • Pull the pivot rod out to expose the ball. Remove the whole pivot rod fixture.
  6. Pop-Up Assembly Stopper Piece Replacement: paso 6, imagen 1 de 2 Pop-Up Assembly Stopper Piece Replacement: paso 6, imagen 2 de 2
    • In the sink, the pop-up stopper will be loose.
    • Pull up on the pop-up stopper to separate it from the main pop-up assembly.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 14
Ultimos 30 días: 52
Todo El Tiempo: 1,471
