Saltar al contenido principal
Polygel Nail Replacement
Qué necesitas
  1. Polygel Nail Replacement, Polygel Nail: paso 1, imagen 1 de 3 Polygel Nail Replacement, Polygel Nail: paso 1, imagen 2 de 3 Polygel Nail Replacement, Polygel Nail: paso 1, imagen 3 de 3
    • Check the extent of the damage.
    • If the damage is minimal, file off any minor nicks around the edge of the nail.
    • If the damage is extensive, the nail needs to be removed and rebuilt.
  2. Polygel Nail Replacement: paso 2, imagen 1 de 3 Polygel Nail Replacement: paso 2, imagen 2 de 3 Polygel Nail Replacement: paso 2, imagen 3 de 3
    • Start by cutting from one side of the nail then going to the other side with the nail clippers.
    • Cutting directly from the center will cause pressure on the natural nail, which is something you should avoid.
  3. Polygel Nail Replacement: paso 3, imagen 1 de 3 Polygel Nail Replacement: paso 3, imagen 2 de 3 Polygel Nail Replacement: paso 3, imagen 3 de 3
    • Start filing off the remaining gel until you are just left with the natural nail as the base.
    • Hold the finger in place to make sure you have control of where you're filing, making sure not to hit any skin.
    • The grit of the file does not matter; polygel is thin and easy to file.
    • File until you see that all the gel is removed.
  4. Polygel Nail Replacement: paso 4, imagen 1 de 3 Polygel Nail Replacement: paso 4, imagen 2 de 3 Polygel Nail Replacement: paso 4, imagen 3 de 3
    • Turn the nail and ensure there's no remaining gel.
  5. Polygel Nail Replacement: paso 5, imagen 1 de 3 Polygel Nail Replacement: paso 5, imagen 2 de 3 Polygel Nail Replacement: paso 5, imagen 3 de 3
    • Dampen a cotton ball with the alcohol and wipe off any dust residue from the filing.
    • The alcohol will also dehydrate the nail and prep it for the base coat.
  6. Polygel Nail Replacement: paso 6, imagen 1 de 3 Polygel Nail Replacement: paso 6, imagen 2 de 3 Polygel Nail Replacement: paso 6, imagen 3 de 3
    • Paint a thin, even layer of base coat onto the natural nail.
    • Wipe off any base coat that gets on the skin.
  7. Polygel Nail Replacement: paso 7, imagen 1 de 3 Polygel Nail Replacement: paso 7, imagen 2 de 3 Polygel Nail Replacement: paso 7, imagen 3 de 3
    • Put your hand inside the UV lamp.
    • Press the 30 second button.
    • Once the 30 seconds have passed, remove your hand from the lamp.
  8. Polygel Nail Replacement: paso 8, imagen 1 de 3 Polygel Nail Replacement: paso 8, imagen 2 de 3 Polygel Nail Replacement: paso 8, imagen 3 de 3
    • Apply a small bead of polygel at the base of the form.
    • Pour alcohol in a dappen dish (or small container) and dip your brush into the alcohol.
    • This prevents the polygel from sticking to the brush.
    • Spread the polygel towards the top of the dual form in an even layer.
  9. Polygel Nail Replacement: paso 9, imagen 1 de 3 Polygel Nail Replacement: paso 9, imagen 2 de 3 Polygel Nail Replacement: paso 9, imagen 3 de 3
    • Hold the finger steady and place the form on the natural nail.
    • With a small amount of pressure, push the dual form down until it stays in place.
    • Wipe off any gel that spills out onto the sides of the nail.
  10. Polygel Nail Replacement: paso 10, imagen 1 de 3 Polygel Nail Replacement: paso 10, imagen 2 de 3 Polygel Nail Replacement: paso 10, imagen 3 de 3
    • Put your hand inside the lamp.
    • Press the 60 second button.
    • After the 60 seconds have passed, remove your hand from the lamp.
  11. Polygel Nail Replacement: paso 11, imagen 1 de 3 Polygel Nail Replacement: paso 11, imagen 2 de 3 Polygel Nail Replacement: paso 11, imagen 3 de 3
    • Grip the dual form from the tip.
    • Pull while moving the form from side to side to pop it off.
  12. Polygel Nail Replacement: paso 12, imagen 1 de 3 Polygel Nail Replacement: paso 12, imagen 2 de 3 Polygel Nail Replacement: paso 12, imagen 3 de 3
    • Dampen one of the cotton balls with the alcohol and wipe off the nail until all the sticky residue is gone.
  13. Polygel Nail Replacement: paso 13, imagen 1 de 3 Polygel Nail Replacement: paso 13, imagen 2 de 3 Polygel Nail Replacement: paso 13, imagen 3 de 3
    • Cut off any length you don't want or need using the nail clippers.
    • Start from one side and then move to the other side.
    • You don't want to cause any pressure or unwanted discomfort on the natural nail by cutting from the center.
  14. Polygel Nail Replacement: paso 14, imagen 1 de 3 Polygel Nail Replacement: paso 14, imagen 2 de 3 Polygel Nail Replacement: paso 14, imagen 3 de 3
    • Start filing and ensure your nail is even all around.
    • File any bumps or unevenness on the surface of the nail.
  15. Polygel Nail Replacement: paso 15, imagen 1 de 3 Polygel Nail Replacement: paso 15, imagen 2 de 3 Polygel Nail Replacement: paso 15, imagen 3 de 3
    • Dampen one of the cotton balls with the alcohol and wipe the nail until there is no longer dust on it.
  16. Polygel Nail Replacement: paso 16, imagen 1 de 3 Polygel Nail Replacement: paso 16, imagen 2 de 3 Polygel Nail Replacement: paso 16, imagen 3 de 3
    • Move the finger to make sure you can see that all sides of the nail are even.
  17. Polygel Nail Replacement: paso 17, imagen 1 de 3 Polygel Nail Replacement: paso 17, imagen 2 de 3 Polygel Nail Replacement: paso 17, imagen 3 de 3
    • Apply a thin layer of top coat onto the gel nail.
  18. Polygel Nail Replacement: paso 18, imagen 1 de 3 Polygel Nail Replacement: paso 18, imagen 2 de 3 Polygel Nail Replacement: paso 18, imagen 3 de 3
    • Put your hand inside and press the 60 second button.
    • Once the 60 seconds have passed, remove your hand from the lamp.
  19. Polygel Nail Replacement: paso 19, imagen 1 de 1
    • After curing your nail, you are done!
    • You can always go back and paint your nails and design them in any desirable manner.
Linea de Meta
Kimberly Gomez
Miembro Desde 04/11/21
289 Reputación
1 Guía escrita
Equipo
Un comentario
It helps me alot. Few days back i got my nail broke. I was in so much pain and looking for how to replace nails and fortunately i found this i ddn’t even waste a second and read it thoroughly and it helps me alot in replacing my nail. Thank you for helping others. Keep shining!
Angelina - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 39
Todo El Tiempo: 1,715
