Introducción
Replacing or adjusting the unresponsive buttons will allow you to use the phone properly if it seems that the buttons or stuck or damaged.
Qué necesitas
Flip the device over. Using a Phillips #00 screwdriver, remove the black 10mm screw on each three legs of the phone.
Using a Phillips #00 screwdriver, remove the two silver 7mm screws as pictured.
Casi Terminas!
Conclusión
