Saltar al contenido principal
Polycom SoundStation Back Housing Replacement
Qué necesitas
  1. Polycom SoundStation Back Housing Replacement, Back Housing: paso 1, imagen 1 de 1
    • Flip the device over. Using a Phillips #00 screwdriver, remove the black 10mm screw on each three legs of the phone.
    • Using a Phillips #00 screwdriver, remove the two silver 7mm screws as pictured.
  2. Polycom SoundStation Back Housing Replacement: paso 2, imagen 1 de 2 Polycom SoundStation Back Housing Replacement: paso 2, imagen 2 de 2
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing off!
Conclusión
Cali Nowak Credit
Miembro Desde 09/02/14
431 Reputación
4 Guías creadas
Equipo
Un comentario
thanks for this - the 7mm were under footpads so I couldn’t see them. cover now off, keyboard dried of coffee and working fine again!!
J M - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 18
Todo El Tiempo: 1,167
