Saltar al contenido principal
Polaroid Z2300 Battery Replacement
  1. Polaroid Z2300 Battery Replacement, Battery: paso 1, imagen 1 de 2 Polaroid Z2300 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Turn the camera upside down and gently use your thumb to pull the hatch forward and then upwards.
    • Once you lift the hatch up you will see the battery.
  2. Polaroid Z2300 Battery Replacement: paso 2, imagen 1 de 2 Polaroid Z2300 Battery Replacement: paso 2, imagen 2 de 2
    • Once you see the battery, you will see a tab saying 'pull' attached to the battery. gently pull on it until the battery is removed from the camera.
    • You can pull the battery easily afterwards.
  3. Polaroid Z2300 Battery Replacement: paso 3, imagen 1 de 1
    • Afterwards, you can easily reattach the battery back.
Conclusión
Jasem Almeeli
Miembro Desde 03/02/17
101 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S13-G1, Cagle Spring 2017 Miembro de USF Tampa, Team S13-G1, Cagle Spring 2017
USFT-CAGLE-S17S13G1
4 Miembros
2 Guías creadas
Un comentario
Do you know where to find a replacement battery? I’ve looked all over the internet.
Wendy Ralph - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 16
Ultimos 30 días: 60
Todo El Tiempo: 3,790
