Saltar al contenido principal
Polaroid Sun 600 LMS Film Pack Replacement
  1. Polaroid Sun 600 LMS Film Pack Replacement, Film Pack: paso 1, imagen 1 de 1
    • Locate film door and slide release latch.
    • The slide release is near the lower left corner towards the front of the camera.
  2. Polaroid Sun 600 LMS Film Pack Replacement: paso 2, imagen 1 de 1
    • Slide side latch towards the front of camera.
    • The film door will pop open.
  3. Polaroid Sun 600 LMS Film Pack Replacement: paso 3, imagen 1 de 1
    • Insert film pack.
    • Make sure the battery contacts on the film pack are facing down and in contact with the camera's contacts.
  4. Polaroid Sun 600 LMS Film Pack Replacement: paso 4, imagen 1 de 1
    • Close film door by gently pushing it back into place.
Linea de Meta
Una persona más ha completado esta guía.
Matthew Lessig
Miembro Desde 01/20/10
63 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 3-18, Maness Winter 2010 Miembro de Cal Poly, Team 3-18, Maness Winter 2010
CPSU-MANESS-W10S3G18
4 Miembros
4 Guías creadas
3 comentarios
Where would you buy the sun 600 LMS battery film?
Albert Einstein - Contestar
Where can I buy Sun 600 LMS instant battery film?
How do you fix the flash
Edward Flores - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 24
Todo El Tiempo: 12,141
