Saltar al contenido principal
Polaroid SNAP Front and Back Face Plate Removal
Sólo Prerrequisito
Esta guía solo debería usarse como prerrequisito para otras guías. Por tanto, estará incompleta.
Qué necesitas
  1. Polaroid SNAP Front and Back Face Plate Removal, Polaroid SNAP Front and Back Face Plate Removal: paso 1, imagen 1 de 1
    • Open the paper door of the camera, then locate and remove the screws that are on the top and bottom edge of the inside of the camera.
    • Screw head: Phillips, Screw length: 3mm
  2. Polaroid SNAP Front and Back Face Plate Removal: paso 2, imagen 1 de 2 Polaroid SNAP Front and Back Face Plate Removal: paso 2, imagen 2 de 2
    • Push the rear face plate from the short side nearest the screws you just removed towards the other short side of the camera. It should slide forward and unlock the clips holding it in place.
    • Then it should be easy to simply lift the rear face plate up and remove it.
  3. Polaroid SNAP Front and Back Face Plate Removal: paso 3, imagen 1 de 2 Polaroid SNAP Front and Back Face Plate Removal: paso 3, imagen 2 de 2
    • Locate and remove the four screws on the corners of the camera, they're quite small and may be difficult to remove.
    • Screw head: Philips, Screw length: 5mm
  4. Polaroid SNAP Front and Back Face Plate Removal: paso 4, imagen 1 de 3 Polaroid SNAP Front and Back Face Plate Removal: paso 4, imagen 2 de 3 Polaroid SNAP Front and Back Face Plate Removal: paso 4, imagen 3 de 3
    • Once the screws are removed, flip the camera over
    • Use a plastic opening tool to disengage the six clips until the front face plate can be removed safely
  5. Polaroid SNAP Front and Back Face Plate Removal: paso 5, imagen 1 de 1
    • The cameras innards should now be accessible to you
Conclusión
Aaron Hall
Miembro Desde 02/09/16
500 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 7-3, Cheng Spring 2016 Miembro de USF Tampa, Team 7-3, Cheng Spring 2016
USFT-CHENG-S16S7G3
4 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 74
