Saltar al contenido principal
Polaroid S7 Digitizer Replacement
Qué necesitas
  1. Polaroid S7 Digitizer Replacement, Remove the back: paso 1, imagen 1 de 2 Polaroid S7 Digitizer Replacement, Remove the back: paso 1, imagen 2 de 2
    • Insert the flat end of one of the plastic opening tools between the screen and the colored back cover. Gently pry apart the pieces.
    • Carefully separate the screen from the back, taking care not to rip the ribbons connecting them.
  2. Polaroid S7 Digitizer Replacement: paso 2, imagen 1 de 2 Polaroid S7 Digitizer Replacement: paso 2, imagen 2 de 2
    • Insert the plastic opening tool into the wedge and pry it open.
  3. Polaroid S7 Digitizer Replacement: paso 3, imagen 1 de 1
    • Open the latch and pull to remove the LCD.
  4. Polaroid S7 Digitizer Replacement, Digitizer: paso 4, imagen 1 de 1
    • After you remove the digitizer, open the latch and remove the screen.
  5. Polaroid S7 Digitizer Replacement: paso 5, imagen 1 de 1
    • To install the new screen, insert the digitizer into the new screen and latch them back in.
Conclusión
Thiago Guedes
Miembro Desde 01/20/15
17 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 1-2, Blackwell Winter 2015 Miembro de USF Tampa, Team 1-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G2
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 173
