Saltar al contenido principal
Polaroid S7 Battery Replacement
Qué necesitas
  1. Polaroid S7 Battery Replacement, Remove the back: paso 1, imagen 1 de 2 Polaroid S7 Battery Replacement, Remove the back: paso 1, imagen 2 de 2
    • Insert the flat end of a soft plastic opening tool between the screen and the back cover.
    • Pry the two pieces apart.
    • Take care not to rip the ribbons that connect the screen to the back cover.
  2. Polaroid S7 Battery Replacement: paso 2, imagen 1 de 1
    • Use a metal spudger to remove the orange sticker.
  3. Polaroid S7 Battery Replacement: paso 3, imagen 1 de 1
    • Use the screwdriver to remove the 2 x 4 mm Phillips #00 head screws from the blue board located on the lower-right corner of the battery.
  4. Polaroid S7 Battery Replacement: paso 4, imagen 1 de 2 Polaroid S7 Battery Replacement: paso 4, imagen 2 de 2
    • Use the metal spudger to remove the three pieces of clear tape adhering from the battery to the blue board.
    • Pry the battery up from the right side.
  5. Polaroid S7 Battery Replacement: paso 5, imagen 1 de 1
    • Remove the yellow plastic that covers the battery connector.
  6. Polaroid S7 Battery Replacement: paso 6, imagen 1 de 1
    • Use a soldering iron to remove the wires connected to the battery.
Conclusión
Equipo
USF Tampa, Team 1-2, Blackwell Winter 2015 Miembro de USF Tampa, Team 1-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G2
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 10
Todo El Tiempo: 3,235
