Saltar al contenido principal
Polaroid S10 Volume and Power Button Replacement
Sólo Prerrequisito
Esta guía solo debería usarse como prerrequisito para otras guías. Por tanto, estará incompleta.
Qué necesitas
  1. Polaroid S10 Volume and Power Button Replacement, Removing the backcover: paso 1, imagen 1 de 3 Polaroid S10 Volume and Power Button Replacement, Removing the backcover: paso 1, imagen 2 de 3 Polaroid S10 Volume and Power Button Replacement, Removing the backcover: paso 1, imagen 3 de 3
    • Place an opening pick between the volume button and the back cover.
    • More than one pick may be needed, but avoid placing more than two picks in the same space.
    • Excessive force on the pick will break the volume button.
    • Carefully remove the back cover using the metal spudger.
    • It is normal to hear a snapping noise due to the plastic tabs on the back cover.
  2. Polaroid S10 Volume and Power Button Replacement, Volume and Power Button Board: paso 2, imagen 1 de 2 Polaroid S10 Volume and Power Button Replacement, Volume and Power Button Board: paso 2, imagen 2 de 2
    • Use the spudger to remove the tape.
    • Remove the 2 J000 4 mm screws using a J000 screwdriver.
    • Carefully disconnect the connector port.
Conclusión
Christofer
Miembro Desde 03/16/15
613 Reputación
6 Guías creadas
Equipo
Colorado Springs, Team 1-4, May Spring 2015 Miembro de Colorado Springs, Team 1-4, May Spring 2015
UCCS-MAY-S15S1G4
Miembros de 4
13 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 22
Todo El Tiempo: 96
