Saltar al contenido principal
Polaroid S10 Battery Replacement
Qué necesitas
  1. Polaroid S10 Battery Replacement, Removing the backcover: paso 1, imagen 1 de 3 Polaroid S10 Battery Replacement, Removing the backcover: paso 1, imagen 2 de 3 Polaroid S10 Battery Replacement, Removing the backcover: paso 1, imagen 3 de 3
    • Place an opening pick between the volume button and the back cover.
    • More than one pick may be needed, but avoid placing more than two picks in the same space.
    • Excessive force on the pick will break the volume button.
    • Carefully remove the back cover using the metal spudger.
    • It is normal to hear a snapping noise due to the plastic tabs on the back cover.
  2. Polaroid S10 Battery Replacement, Battery: paso 2, imagen 1 de 3 Polaroid S10 Battery Replacement, Battery: paso 2, imagen 2 de 3 Polaroid S10 Battery Replacement, Battery: paso 2, imagen 3 de 3
    • Use a spudger to carefully remove the tape nearest to the battery.
    • Use caution while removing tape. Too much force can damage the device.
    • Gently use the spudger to remove the battery out of place by wedging it out from the bottom.
    • Do not move the battery. Moving it could cause the cables to be ripped out.
  3. Polaroid S10 Battery Replacement, Battery Connection: paso 3, imagen 1 de 2 Polaroid S10 Battery Replacement, Battery Connection: paso 3, imagen 2 de 2
    • Carefully desolder the 2 wires that connect the battery to the motherboard.
    • Do not touch the soldering iron to the motherboard or the LCD screen.
Conclusión
Follow these instructions to reassemble your device.
Una persona más ha completado esta guía.
James
Miembro Desde 03/16/15
367 Reputación
3 Guías creadas
Equipo
Colorado Springs, Team 1-4, May Spring 2015 Miembro de Colorado Springs, Team 1-4, May Spring 2015
UCCS-MAY-S15S1G4
Miembros de 4
13 Guías creadas
Un comentario
Can't open the %#*@ thing!!!!!!!!!!
tosaguys - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 28
Todo El Tiempo: 5,277
