Saltar al contenido principal
Polaroid PTAB7XC USB Port Replacement
Qué necesitas
  1. Polaroid PTAB7XC USB Port Replacement, USB Port: paso 1, imagen 1 de 2 Polaroid PTAB7XC USB Port Replacement, USB Port: paso 1, imagen 2 de 2
    • Remove the two 7 mm screws on the top of the device using a J00 Phillips screwdriver, turning the screws counterclockwise.
    • If the screw heads have corroded or been stripped, it may be necessary to use a larger screwdriver head, such as the J0.
  2. Polaroid PTAB7XC USB Port Replacement: paso 2, imagen 1 de 2 Polaroid PTAB7XC USB Port Replacement: paso 2, imagen 2 de 2
    • Pry the seam between the screen and the case on all four sides with a large plastic opening tool until the plastic case comes off.
    • Lift the device off of the case and flip over the device so that it sits screen side down.
    • The device is now free from the plastic casing.
    • The power and/or volume buttons may fall out at this point. There is no problem with this; however, be sure to remember to reinstall them when reassembling the device.
  3. Polaroid PTAB7XC USB Port Replacement: paso 3, imagen 1 de 3 Polaroid PTAB7XC USB Port Replacement: paso 3, imagen 2 de 3 Polaroid PTAB7XC USB Port Replacement: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Desolder the following components from the motherboard.
    • Desolder from the motherboard the red wire that connects to the speaker unit.
    • Desolder from the motherboard the black wire that connects to the speaker unit.
    • Desolder from the motherboard the gray wire that runs along the edge of the device.
    • Desolder from the motherboard the red wire that connects to the battery unit.
    • Desolder from the motherboard the black wire that connects to the battery unit.
    • The motherboard will now be detached from any wires connecting to the device.
    • If any of the wires do not detach completely during the desoldering process, then gently pull them off using tweezers.
  4. Polaroid PTAB7XC USB Port Replacement: paso 4, imagen 1 de 3 Polaroid PTAB7XC USB Port Replacement: paso 4, imagen 2 de 3 Polaroid PTAB7XC USB Port Replacement: paso 4, imagen 3 de 3
    • Use tweezers to unstick the medium width yellow ribbon cable from the motherboard.
    • Use a small plastic opening tool to slide the two small black holding clips off of the white connector to which the medium width yellow ribbon cable is attached.
    • Use your fingers to gently pull the medium width yellow ribbon cable out of the white connector.
    • Repeat the last two actions to disconnect the narrower yellow ribbon cable and the wider yellow ribbon cable from the motherboard.
    • The motherboard and battery will now be detached from any ribbon cables connecting to the device.
  5. Polaroid PTAB7XC USB Port Replacement: paso 5, imagen 1 de 3 Polaroid PTAB7XC USB Port Replacement: paso 5, imagen 2 de 3 Polaroid PTAB7XC USB Port Replacement: paso 5, imagen 3 de 3
    • Use the PH000 screwdriver remove the four 5 mm screws along the bottom edge of the motherboard, turning the screws counterclockwise.
    • The motherboard is now detached from the device.
  6. Polaroid PTAB7XC USB Port Replacement: paso 6, imagen 1 de 1
    • Lift the motherboard out of the device using your hands.
    • Set the motherboard down on a heat safe surface so that the gray side of the motherboard is face up.
  7. Polaroid PTAB7XC USB Port Replacement: paso 7, imagen 1 de 1
    • Desolder each side of the USB port where it is attached to the motherboard.
    • The USB port will now be loosened from the motherboard.
  8. Polaroid PTAB7XC USB Port Replacement: paso 8, imagen 1 de 1
    • Using tweezers, pull the USB port straight out from the motherboard without wiggling it up, down, or side to side.
    • Wiggling the port may break the small connectors that remain attached to the motherboard.
    • The USB port is now replaceable.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 345
