Saltar al contenido principal
Polaroid PMID701i 10 USB Charging Port Replacement
Qué necesitas
  1. Polaroid PMID701i 10 USB Charging Port Replacement, Panel: paso 1, imagen 1 de 2 Polaroid PMID701i 10 USB Charging Port Replacement, Panel: paso 1, imagen 2 de 2
    • Turn off and unplug the device before starting replacement.
    • Flip the device so that the screen faces down, with the back facing up.
    • The back panel attaches to the device with four 4.0mm long screws, one at each corner, indicated by the red circles in the picture.
    • Unscrew the four screws with a PH000 screwdriver.
  2. Polaroid PMID701i 10 USB Charging Port Replacement: paso 2, imagen 1 de 2 Polaroid PMID701i 10 USB Charging Port Replacement: paso 2, imagen 2 de 2
    • Flip the device over so that the screen faces up, and the back faces down.
    • Separate the front panel using the Opening Tool on a corner to create an opening.
    • Removing the frame for the first time may take a significant amount of force.
    • Run the tool along the seams of the device to open up all the sides.
  3. Polaroid PMID701i 10 USB Charging Port Replacement: paso 3, imagen 1 de 1
    • Removing the panel too quickly may damage the cable that attaches parts between the two panels.
    • Gently lift the top panel from the bottom panel.
  4. Polaroid PMID701i 10 USB Charging Port Replacement: paso 4, imagen 1 de 2 Polaroid PMID701i 10 USB Charging Port Replacement: paso 4, imagen 2 de 2
    • The flexible flat cables (FFC) attach to parts in the bottom panel with zero insertion force (ZIF) connectors.
    • Use the Opening tool to flip up the black retaining flap on the smaller connector.
    • Gently lift the cable, parallel to the panel, to detach it.
  5. Polaroid PMID701i 10 USB Charging Port Replacement: paso 5, imagen 1 de 2 Polaroid PMID701i 10 USB Charging Port Replacement: paso 5, imagen 2 de 2
    • Use the Opening tool to flip up the black retaining flap on the larger connector.
  6. Polaroid PMID701i 10 USB Charging Port Replacement, USB Charging Port: paso 6, imagen 1 de 2 Polaroid PMID701i 10 USB Charging Port Replacement, USB Charging Port: paso 6, imagen 2 de 2
    • The motherboard attaches to the back panel with three 3.5mm long screws.
    • Unscrew the three screws with a PH000 screwdriver.
  7. Polaroid PMID701i 10 USB Charging Port Replacement: paso 7, imagen 1 de 2 Polaroid PMID701i 10 USB Charging Port Replacement: paso 7, imagen 2 de 2
    • Solder beads attach the wires that connect the motherboard to other parts, such as the battery and the speaker.
    • Desolder the wires from the motherboard. For detailed information, refer to the Solder and Desolder guide.
  8. Polaroid PMID701i 10 USB Charging Port Replacement: paso 8, imagen 1 de 2 Polaroid PMID701i 10 USB Charging Port Replacement: paso 8, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Some of the wires attach to the panel with tape as well.
    • Use tweezers to gently lift the tape from the wires and plastic.
  9. Polaroid PMID701i 10 USB Charging Port Replacement: paso 9, imagen 1 de 1
    • Use tweezers to gently lift the yellow tape that tapes down the yellow flat cable.
    • Desolder the flat cable.
  10. Polaroid PMID701i 10 USB Charging Port Replacement: paso 10, imagen 1 de 2 Polaroid PMID701i 10 USB Charging Port Replacement: paso 10, imagen 2 de 2
    • There is a grey wire attached to the back side of the motherboard.
    • Flip the motherboard over to the side so that the grey wire and its solder bead faces up.
    • Desolder the gray wire from the motherboard.
  11. Polaroid PMID701i 10 USB Charging Port Replacement: paso 11, imagen 1 de 2 Polaroid PMID701i 10 USB Charging Port Replacement: paso 11, imagen 2 de 2
    • Use tweezers to lift the motherboard from the panel.
Conclusión
Una persona más ha completado esta guía.
Amy Li
Miembro Desde 01/31/17
627 Reputación
5 Guías creadas
Equipo
Baylor, Team 3-4, Whitney Spring 2017 Miembro de Baylor, Team 3-4, Whitney Spring 2017
BU-WHITNEY-S17S3G4
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 213
