Saltar al contenido principal
Polaroid PMID701i 10 Battery Replacement
Qué necesitas
  1. Polaroid PMID701i 10 Battery Replacement, Panel: paso 1, imagen 1 de 2 Polaroid PMID701i 10 Battery Replacement, Panel: paso 1, imagen 2 de 2
    • Turn off and unplug the device before starting replacement.
    • Flip the device so that the screen faces down, with the back facing up.
    • The back panel attaches to the device with four 4.0mm long screws, one at each corner, indicated by the red circles in the picture.
    • Unscrew the four screws with a PH000 screwdriver.
  2. Polaroid PMID701i 10 Battery Replacement: paso 2, imagen 1 de 2 Polaroid PMID701i 10 Battery Replacement: paso 2, imagen 2 de 2
    • Flip the device over so that the screen faces up, and the back faces down.
    • Separate the front panel using the Opening Tool on a corner to create an opening.
    • Removing the frame for the first time may take a significant amount of force.
    • Run the tool along the seams of the device to open up all the sides.
  3. Polaroid PMID701i 10 Battery Replacement: paso 3, imagen 1 de 1
    • Removing the panel too quickly may damage the cable that attaches parts between the two panels.
    • Gently lift the top panel from the bottom panel.
  4. Polaroid PMID701i 10 Battery Replacement: paso 4, imagen 1 de 2 Polaroid PMID701i 10 Battery Replacement: paso 4, imagen 2 de 2
    • The flexible flat cables (FFC) attach to parts in the bottom panel with zero insertion force (ZIF) connectors.
    • Use the Opening tool to flip up the black retaining flap on the smaller connector.
    • Gently lift the cable, parallel to the panel, to detach it.
  5. Polaroid PMID701i 10 Battery Replacement: paso 5, imagen 1 de 2 Polaroid PMID701i 10 Battery Replacement: paso 5, imagen 2 de 2
    • Use the Opening tool to flip up the black retaining flap on the larger connector.
  6. Polaroid PMID701i 10 Battery Replacement, Battery: paso 6, imagen 1 de 1
    • The battery is wrapped with tape. It is attached to the back plastic panel by glue.
    • The battery may bend if detached using a spudger or other small tool.
    • Grip the the battery by hand.
    • Due to the glue and shape of the battery it, it may take a significant amount of force to lift it.
    • Lift the battery, by hand, to remove it from the glue and panel.
  7. Polaroid PMID701i 10 Battery Replacement: paso 7, imagen 1 de 1
    • The battery attaches to the motherboard with two wires, one red and one black.
    • Desolder the wires from the motherboard. For detailed information, refer to the Solder and Desolder guide.
  8. Polaroid PMID701i 10 Battery Replacement: paso 8, imagen 1 de 1
    • Gently remove the battery, with the wires, from the panel and motherboard completely.
Conclusión
Una persona más ha completado esta guía.
Amy Li
Miembro Desde 01/31/17
627 Reputación
5 Guías creadas
Equipo
Baylor, Team 3-4, Whitney Spring 2017 Miembro de Baylor, Team 3-4, Whitney Spring 2017
BU-WHITNEY-S17S3G4
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 273
