Introducción
If your device has poor sound quality, follow this guide to remove the speaker.
Qué necesitas
Pry the seam between the screen and the case and slide it on all four sides with a large plastic opening tool until the plastic case comes off.
Herramienta utilizada en este paso:Plastic Cards$2.99
Wedge a plastic card beneath the battery unit and wiggle the card side to side and up and down gently until the glue sealing the battery to the device is broken.
Remove the two 5mm screws attached to the top right and bottom left corners of the speaker
