Saltar al contenido principal
Polaroid PMID4312 Battery Replacement
Qué necesitas
  1. Polaroid PMID4312 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Pry the seam between the screen and the case and slide it on all four sides with a large plastic opening tool until the plastic case comes off.
  2. Polaroid PMID4312 Battery Replacement: paso 2, imagen 1 de 1
    • Lift the device off of the case and flip over the device so that it sits screen side down.
  3. Polaroid PMID4312 Battery Replacement: paso 3, imagen 1 de 1
    • The device is now free from the plastic case.
  4. Polaroid PMID4312 Battery Replacement: paso 4, imagen 1 de 2 Polaroid PMID4312 Battery Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Plastic Cards
    $2.99
    Comprar
    • Wedge a plastic card beneath the battery unit and wiggle the card side to side and up and down gently until the glue sealing the battery to the device is broken.
  5. Polaroid PMID4312 Battery Replacement: paso 5, imagen 1 de 1
    • Peel back any yellow tape not directly attached to the battery.
    • Using a soldering iron, desolder the two wires that connect the battery to the motherboard.
Conclusión
Equipo
USF Tampa, Team 5-4, Lacy Fall 2016 Miembro de USF Tampa, Team 5-4, Lacy Fall 2016
USFT-LACY-F16S5G4
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 601
