Saltar al contenido principal
Polaroid Onestep Close Up Shutter Switch Replacement
Qué necesitas
  1. Polaroid Onestep Close Up Shutter Switch Replacement, Flash Assembly Removal: paso 1, imagen 1 de 3 Polaroid Onestep Close Up Shutter Switch Replacement, Flash Assembly Removal: paso 1, imagen 2 de 3 Polaroid Onestep Close Up Shutter Switch Replacement, Flash Assembly Removal: paso 1, imagen 3 de 3
    • Begin by opening the top of the camera (flash assembly) to a slight angle.
    • Next, angle the flash assembly slightly upward and pry off the connections carefully.
    • Be careful not to damage the ribbon cable. This is essential to the operation of the flash.
  2. Polaroid Onestep Close Up Shutter Switch Replacement, Opening Film Tray: paso 2, imagen 1 de 2 Polaroid Onestep Close Up Shutter Switch Replacement, Opening Film Tray: paso 2, imagen 2 de 2
    • Slide the action button, on the bottom of the camera, to open the bottom.
  3. Polaroid Onestep Close Up Shutter Switch Replacement, Removing Face Plate: paso 3, imagen 1 de 3 Polaroid Onestep Close Up Shutter Switch Replacement, Removing Face Plate: paso 3, imagen 2 de 3 Polaroid Onestep Close Up Shutter Switch Replacement, Removing Face Plate: paso 3, imagen 3 de 3
    • Insert the blue plastic opening tool between the rear case and the plastic tabs directly under the shelf, and pry it loose.
    • Pull off the face plate.
  4. Polaroid Onestep Close Up Shutter Switch Replacement, Shutter Switch Removal: paso 4, imagen 1 de 3 Polaroid Onestep Close Up Shutter Switch Replacement, Shutter Switch Removal: paso 4, imagen 2 de 3 Polaroid Onestep Close Up Shutter Switch Replacement, Shutter Switch Removal: paso 4, imagen 3 de 3
    • After the face plate is off, the shutter switch should slide out easily.
Conclusión
3 personas más completaron esta guía.
Tyler OBrien
Miembro Desde 09/22/14
627 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 3-5, Brown Fall 2014 Miembro de USF Tampa, Team 3-5, Brown Fall 2014
USFT-BROWN-F14S3G5
3 Miembros
6 Guías creadas
2 comentarios
where did you get the replacement parts for this?
Jacob Sokolove - Contestar
I’d love to find a new shutter piece..
Joni Korkkula - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 34
Todo El Tiempo: 3,942
