Introducción
If you need to replace the film door latch, use this guide to access the inside of the camera. You may need to replace the latch if your camera will not close.
Qué necesitas
Unscrew the four 5mm screws on the base of the camera using a Phillips #0 screwdriver.
4 personas más completaron esta guía.
2 comentarios
This doesn’t actually say anything about replacing the latch…
But where do you buy a replacement latch?
