Saltar al contenido principal
Polaroid One-Step 600 Battery Cartridge Replacement
  1. Polaroid One-Step 600 Battery Cartridge Replacement, Battery Cartridge: paso 1, imagen 1 de 3 Polaroid One-Step 600 Battery Cartridge Replacement, Battery Cartridge: paso 1, imagen 2 de 3 Polaroid One-Step 600 Battery Cartridge Replacement, Battery Cartridge: paso 1, imagen 3 de 3
    • Open the bottom compartment of the camera by sliding the lever towards the opening.
  2. Polaroid One-Step 600 Battery Cartridge Replacement: paso 2, imagen 1 de 1
    • Remove old battery/ film cartridge from camera.
  3. Polaroid One-Step 600 Battery Cartridge Replacement: paso 3, imagen 1 de 1
    • Follow the instructions that came with the new battery/ film cartridge to insert the new cartridge into the camera.
    • Close the battery compartment of the camera.
    • Note: The camera in this picture does not contain a battery.
Linea de Meta
13 personas más completaron esta guía.
Doug Jimenez
Miembro Desde 01/21/10
538 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 16-31, Maness Winter 2010 Miembro de Cal Poly, Team 16-31, Maness Winter 2010
CPSU-MANESS-W10S16G31
4 Miembros
6 Guías creadas
13 comentarios
It worked but its expensive
Jessica diaz - Contestar
I put new film in, it´s turning on, the flash is going off, but no film is coming out after the flash. What is the problem?
tristanmoeller2013 - Contestar
nothing happened
new film installed
no sound
no flash
no action
eminickstone - Contestar
I'm having the same issue
Marie -
I'm having same issue.
Marie -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 12
Ultimos 7 días: 93
Ultimos 30 días: 413
Todo El Tiempo: 149,452
