Saltar al contenido principal
Polaroid Cube Video Quality Switch Replacement
Qué necesitas
  1. Polaroid Cube Video Quality Switch Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the SD card cover by twisting it using a Plastic Opening Tool
  2. Polaroid Cube Video Quality Switch Replacement: paso 2, imagen 1 de 1
    • Use the Plastic Opening tool to pry off and remove the front cover.
  3. Polaroid Cube Video Quality Switch Replacement: paso 3, imagen 1 de 1
    • Using a J00 head screwdriver, remove the four 3.27mm screws from the front of the camera near the lens.
  4. Polaroid Cube Video Quality Switch Replacement: paso 4, imagen 1 de 2 Polaroid Cube Video Quality Switch Replacement: paso 4, imagen 2 de 2
    • Use the Plastic Opening Tool to pry open the shell of the camera.
    • There are four latches, one at each corner, that you will need to detach.
  5. Polaroid Cube Video Quality Switch Replacement: paso 5, imagen 1 de 1
    • Remove shell from top and bottom of camera.
  6. Polaroid Cube Video Quality Switch Replacement: paso 6, imagen 1 de 1
    • Remove the rubber seal wrapped around the camera.
  7. Polaroid Cube Video Quality Switch Replacement: paso 7, imagen 1 de 2 Polaroid Cube Video Quality Switch Replacement: paso 7, imagen 2 de 2
    • Remove the tape wrapped around the battery.
  8. Polaroid Cube Video Quality Switch Replacement: paso 8, imagen 1 de 3 Polaroid Cube Video Quality Switch Replacement: paso 8, imagen 2 de 3 Polaroid Cube Video Quality Switch Replacement: paso 8, imagen 3 de 3
    • Using a J00 head screwdriver, unscrew the four 3.46mm screws from the top and bottom circuit board.
  9. Polaroid Cube Video Quality Switch Replacement: paso 9, imagen 1 de 2 Polaroid Cube Video Quality Switch Replacement: paso 9, imagen 2 de 2
    • Use the plastic opening tool to remove the circuit board that the battery is connected to.
  10. Polaroid Cube Video Quality Switch Replacement: paso 10, imagen 1 de 1
    • Gently remove the battery pin connector from the circuit board.
  11. Polaroid Cube Video Quality Switch Replacement, Video Quality Switch: paso 11, imagen 1 de 2 Polaroid Cube Video Quality Switch Replacement, Video Quality Switch: paso 11, imagen 2 de 2
    • Using a J00 head screwdriver, unscrew the 3.46mm screw that connects the top circuit board to the video quality switch board.
  12. Polaroid Cube Video Quality Switch Replacement: paso 12, imagen 1 de 1
    • Remove the circuit board.
  13. Polaroid Cube Video Quality Switch Replacement: paso 13, imagen 1 de 2 Polaroid Cube Video Quality Switch Replacement: paso 13, imagen 2 de 2
    • Using a J00 head screwdriver, unscrew the two 3.46mm screws connecting the video quality switch to the case.
    • Remove and replace the broken video quality switch.
Conclusión
4 personas más completaron esta guía.
Grant Baldwin
Miembro Desde 09/29/16
685 Reputación
2 Guías creadas
Equipo
IUPUI, Team 3-2, Harley Fall 2016 Miembro de IUPUI, Team 3-2, Harley Fall 2016
IUPUI-HARLEY-F16S3G2
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 16
Todo El Tiempo: 873
