Saltar al contenido principal
Polaroid Cube Lens Replacement
Qué necesitas
  1. Polaroid Cube Lens Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the SD card cover by twisting it using a Plastic Opening Tool
  2. Polaroid Cube Lens Replacement: paso 2, imagen 1 de 1
    • Use the Plastic Opening tool to pry off and remove the front cover.
  3. Polaroid Cube Lens Replacement: paso 3, imagen 1 de 1
    • Using a J00 head screwdriver, remove the four 3.27mm screws from the front of the camera near the lens.
  4. Polaroid Cube Lens Replacement: paso 4, imagen 1 de 2 Polaroid Cube Lens Replacement: paso 4, imagen 2 de 2
    • Use the Plastic Opening Tool to pry open the shell of the camera.
    • There are four latches, one at each corner, that you will need to detach.
  5. Polaroid Cube Lens Replacement: paso 5, imagen 1 de 1
    • Remove shell from top and bottom of camera.
  6. Polaroid Cube Lens Replacement: paso 6, imagen 1 de 1
    • Remove the rubber seal wrapped around the camera.
  7. Polaroid Cube Lens Replacement: paso 7, imagen 1 de 2 Polaroid Cube Lens Replacement: paso 7, imagen 2 de 2
    • Remove the tape wrapped around the battery.
  8. Polaroid Cube Lens Replacement: paso 8, imagen 1 de 3 Polaroid Cube Lens Replacement: paso 8, imagen 2 de 3 Polaroid Cube Lens Replacement: paso 8, imagen 3 de 3
    • Using a J00 head screwdriver, unscrew the four 3.46mm screws from the top and bottom circuit board.
  9. Polaroid Cube Lens Replacement: paso 9, imagen 1 de 2 Polaroid Cube Lens Replacement: paso 9, imagen 2 de 2
    • Use the plastic opening tool to remove the circuit board that the battery is connected to.
  10. Polaroid Cube Lens Replacement: paso 10, imagen 1 de 1
    • Gently remove the battery pin connector from the circuit board.
  11. Polaroid Cube Lens Replacement, Lens: paso 11, imagen 1 de 2 Polaroid Cube Lens Replacement, Lens: paso 11, imagen 2 de 2
    • Use a J00 screwdriver to unscrew the two circled 3.5mm Phillips-head screws from the circuit board.
  12. Polaroid Cube Lens Replacement: paso 12, imagen 1 de 2 Polaroid Cube Lens Replacement: paso 12, imagen 2 de 2
    • Use a J00 head screwdriver to unscrew the two 3.5mm screws from the circuit board.
  13. Polaroid Cube Lens Replacement: paso 13, imagen 1 de 1
    • Remove the lens from the unscrewed circuit board and replace the broken lens.
Conclusión
4 personas más completaron esta guía.
Grant Baldwin
Miembro Desde 09/29/16
685 Reputación
2 Guías creadas
Equipo
IUPUI, Team 3-2, Harley Fall 2016 Miembro de IUPUI, Team 3-2, Harley Fall 2016
IUPUI-HARLEY-F16S3G2
4 Miembros
3 Guías creadas
2 comentarios
Where can I find a replacement lens for the cube+? I broke the bubble part of the lens
Ben McAlister - Contestar
Maybe is posable replace wider view angle lens ? original looks like fpv camera lens foxeer or runcam micro. Possibly Caddx micro cam lens
starsas777 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 43
Todo El Tiempo: 2,317
