Saltar al contenido principal
Polaroid Cube Battery Replacement
Qué necesitas
  1. Polaroid Cube Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the SD card cover by twisting it using a Plastic Opening Tool
  2. Polaroid Cube Battery Replacement: paso 2, imagen 1 de 1
    • Use the Plastic Opening tool to pry off and remove the front cover.
  3. Polaroid Cube Battery Replacement: paso 3, imagen 1 de 1
    • Using a J00 head screwdriver, remove the four 3.27mm screws from the front of the camera near the lens.
  4. Polaroid Cube Battery Replacement: paso 4, imagen 1 de 2 Polaroid Cube Battery Replacement: paso 4, imagen 2 de 2
    • Use the Plastic Opening Tool to pry open the shell of the camera.
    • There are four latches, one at each corner, that you will need to detach.
  5. Polaroid Cube Battery Replacement: paso 5, imagen 1 de 1
    • Remove shell from top and bottom of camera.
  6. Polaroid Cube Battery Replacement: paso 6, imagen 1 de 1
    • Remove the rubber seal wrapped around the camera.
  7. Polaroid Cube Battery Replacement: paso 7, imagen 1 de 2 Polaroid Cube Battery Replacement: paso 7, imagen 2 de 2
    • Remove the tape wrapped around the battery.
  8. Polaroid Cube Battery Replacement: paso 8, imagen 1 de 3 Polaroid Cube Battery Replacement: paso 8, imagen 2 de 3 Polaroid Cube Battery Replacement: paso 8, imagen 3 de 3
    • Using a J00 head screwdriver, unscrew the four 3.46mm screws from the top and bottom circuit board.
  9. Polaroid Cube Battery Replacement: paso 9, imagen 1 de 2 Polaroid Cube Battery Replacement: paso 9, imagen 2 de 2
    • Use the plastic opening tool to remove the circuit board that the battery is connected to.
  10. Polaroid Cube Battery Replacement: paso 10, imagen 1 de 1
    • Gently remove the battery pin connector from the circuit board.
Conclusión
10 personas más completaron esta guía.
heath lamkin
Miembro Desde 09/29/16
372 Reputación
1 Guía escrita
Equipo
IUPUI, Team 3-2, Harley Fall 2016 Miembro de IUPUI, Team 3-2, Harley Fall 2016
IUPUI-HARLEY-F16S3G2
4 Miembros
3 Guías creadas
13 comentarios
Any idea where to find the replacement batteries?
hooverhogg - Contestar
Well described! Need to buy a replacement battery though but I have no idea about the specs of the battery. Any information?
seyhangul - Contestar
Fuji 402424 Lithium ion (Pouch)battery 240mA 4.8V Can’t find it. Can anyone help with a source?
David F O'Connor -
Was anyone able to to find the replacement batteries for the Cube?
yzorger - Contestar
the cube requires a two-pack battery which has a single plug for both of them and so they have to be wired together in just the right way to be able to fit inside the cube. i guess it's not possible to buy replacement batt. and paying minimum $16 for it? u could just buy a new one for too close to $16. or a used one.
Timothy Davenport - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 46
Todo El Tiempo: 9,220
