Saltar al contenido principal
Polaroid Automatic 100 Bellows Replacement
Qué necesitas
  1. Polaroid Automatic 100 Bellows Replacement, Bellows: paso 1, imagen 1 de 3 Polaroid Automatic 100 Bellows Replacement, Bellows: paso 1, imagen 2 de 3 Polaroid Automatic 100 Bellows Replacement, Bellows: paso 1, imagen 3 de 3
    • Fully extend the bellows by lifting the #1 lever.
    • Remove the camera cover in order to make the camera easier to work with.
    • When collapsing bellows, press down on the metal frame above the bellows.
  2. Polaroid Automatic 100 Bellows Replacement: paso 2, imagen 1 de 1
    • Peel the two battery cable tabs off of the bellows.
  3. Polaroid Automatic 100 Bellows Replacement: paso 3, imagen 1 de 1
    Herramienta utilizada en este paso:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Comprar
    • Remove one 15.5 mm flat head screw, with a 2.5 flathead screwdriver.
    • Remove two 2 mm flat head screws, with a 2.5 flathead screwdriver. Then carefully remove the cable cover.
    • Use the focus bar to extend bellows even further to access screws easier with the screwdriver.
  4. Polaroid Automatic 100 Bellows Replacement: paso 4, imagen 1 de 2 Polaroid Automatic 100 Bellows Replacement: paso 4, imagen 2 de 2
    • Open the back cover by pushing the lever on the bottom towards the left.
  5. Polaroid Automatic 100 Bellows Replacement: paso 5, imagen 1 de 1
    • Remove the four 3 mm screws, which are attached to the lens of the camera, using a Phillips #0 screwdriver.
    • To make the screws easily accessible, close the bellows by pushing on the metal frame.
    • When reassembling, orient the camera so that screws are screwed in downward and stay in place.
  6. Polaroid Automatic 100 Bellows Replacement: paso 6, imagen 1 de 1
    • Carefully use a classic wide metal spudger to bend the tabs of the bellows.
  7. Polaroid Automatic 100 Bellows Replacement: paso 7, imagen 1 de 2 Polaroid Automatic 100 Bellows Replacement: paso 7, imagen 2 de 2
    • Pull the bellow tabs back with long needle nose pliers.
    • Remove the bellows.
Conclusión
2 personas más completaron esta guía.
Katie Miller
Miembro Desde 04/14/15
680 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 4-3, Maness Spring 2015 Miembro de Cal Poly, Team 4-3, Maness Spring 2015
CPSU-MANESS-S15S4G3
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 2,032
