Saltar al contenido principal
Polar V800 Charging Port Cover Replacement
Qué necesitas
  1. Polar V800 Charging Port Cover Replacement, Watch Band: paso 1, imagen 1 de 3 Polar V800 Charging Port Cover Replacement, Watch Band: paso 1, imagen 2 de 3 Polar V800 Charging Port Cover Replacement, Watch Band: paso 1, imagen 3 de 3
    • Using a narrow object like a paperclip, push the pins located in the watch band in the direction of the arrow indicated on the watch.
    • Completely pull out the pins.
    • It isn't necessary to remove the watch band before replacing other parts of the watch, but it may make removal of other elements of the watch more accessible and clear.
    • When replacing the charging port cover, only take out the pin that is closest to the charging port cover.
  2. Polar V800 Charging Port Cover Replacement: paso 2, imagen 1 de 3 Polar V800 Charging Port Cover Replacement: paso 2, imagen 2 de 3 Polar V800 Charging Port Cover Replacement: paso 2, imagen 3 de 3
    • To remove the watch band, pull each end of the watch band away from the watch frame.
  3. Polar V800 Charging Port Cover Replacement, Charging Port Cover: paso 3, imagen 1 de 3 Polar V800 Charging Port Cover Replacement, Charging Port Cover: paso 3, imagen 2 de 3 Polar V800 Charging Port Cover Replacement, Charging Port Cover: paso 3, imagen 3 de 3
    • Take off the charging port cover.
Conclusión
Una persona más ha completado esta guía.
Nick B.
Miembro Desde 04/29/18
387 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S17-G6, Livingston Spring 2018 Miembro de Cal Poly, Team S17-G6, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G6
4 Miembros
8 Guías creadas
Un comentario
where does not procure the battery port cover ?
Chenthill P - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 2,971
