Introducción
This guide shows how to replace a defective battery from a Poin2 Chromebook 11, remove the battery to test the device's power adapter, or remove the battery in order to access another component.
Qué necesitas
Power down the Poin2 Chromebook 11 and disconnect the power adapter.
Close the Chromebook and position it with the base facing up.
Use a #0 Phillips screwdriver to unscrew the ten 7mm screws that hold the base to the rest of the frame
To reassemble your Poin2 Chromebook 11, follow these instructions in reverse order.
2 personas más completaron esta guía.
Un comentario
An important piece of information missing is the battery replacement number.
a Google search brings up no references.
