Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
PocketBook Verse PB629 Screen Replacement
  1. PocketBook Verse PB629 Screen Replacement, Remove back cover: paso 1, imagen 1 de 2 PocketBook Verse PB629 Screen Replacement, Remove back cover: paso 1, imagen 2 de 2
    • Pry open with picks or plastic cards.
    • Some force is need. Try pulling outwards to unleash the hooks. Start on one side and work your way around leaving picks in.
    Pregunta a FixBot
    Agregar Comentario
  2. PocketBook Verse PB629 Screen Replacement, Romove connectors covers: paso 2, imagen 1 de 2 PocketBook Verse PB629 Screen Replacement, Romove connectors covers: paso 2, imagen 2 de 2
    • Remove all covers of the connectors.
    Pregunta a FixBot
    Agregar Comentario
  3. PocketBook Verse PB629 Screen Replacement, Remove battery connector: paso 3, imagen 1 de 3 PocketBook Verse PB629 Screen Replacement, Remove battery connector: paso 3, imagen 2 de 3 PocketBook Verse PB629 Screen Replacement, Remove battery connector: paso 3, imagen 3 de 3
    • Lift up the connector from the top.
    Pregunta a FixBot
    Agregar Comentario
  4. PocketBook Verse PB629 Screen Replacement, Remove Screen connector: paso 4, imagen 1 de 3 PocketBook Verse PB629 Screen Replacement, Remove Screen connector: paso 4, imagen 2 de 3 PocketBook Verse PB629 Screen Replacement, Remove Screen connector: paso 4, imagen 3 de 3
    • Flip up the black switch.
    • Pull out the flexcable.
    Pregunta a FixBot
    Agregar Comentario
  5. PocketBook Verse PB629 Screen Replacement, Remove back lighting connector: paso 5, imagen 1 de 3 PocketBook Verse PB629 Screen Replacement, Remove back lighting connector: paso 5, imagen 2 de 3 PocketBook Verse PB629 Screen Replacement, Remove back lighting connector: paso 5, imagen 3 de 3
    Pregunta a FixBot
    Agregar Comentario
  6. PocketBook Verse PB629 Screen Replacement, Remove touch screen connector: paso 6, imagen 1 de 3 PocketBook Verse PB629 Screen Replacement, Remove touch screen connector: paso 6, imagen 2 de 3 PocketBook Verse PB629 Screen Replacement, Remove touch screen connector: paso 6, imagen 3 de 3
    • Flick black switch
    Pregunta a FixBot
    Agregar Comentario
  7. PocketBook Verse PB629 Screen Replacement, Pull out the board: paso 7, imagen 1 de 3 PocketBook Verse PB629 Screen Replacement, Pull out the board: paso 7, imagen 2 de 3 PocketBook Verse PB629 Screen Replacement, Pull out the board: paso 7, imagen 3 de 3
    • Unscrew the screws of the board
    • Pry out the board starting from the bottom.
    • Carefully pull out the flex cables.
    Pregunta a FixBot
    Agregar Comentario
  8. PocketBook Verse PB629 Screen Replacement, Unscrew: paso 8, imagen 1 de 1
    • Unscrew
    Pregunta a FixBot
    Agregar Comentario
  9. PocketBook Verse PB629 Screen Replacement, Bend Flexcable: paso 9, imagen 1 de 2 PocketBook Verse PB629 Screen Replacement, Bend Flexcable: paso 9, imagen 2 de 2
    • Bend away flex cable, so that we are free for the next step.
    Pregunta a FixBot
    Agregar Comentario
  10. PocketBook Verse PB629 Screen Replacement, Remove back cover of screen: paso 10, imagen 1 de 3 PocketBook Verse PB629 Screen Replacement, Remove back cover of screen: paso 10, imagen 2 de 3 PocketBook Verse PB629 Screen Replacement, Remove back cover of screen: paso 10, imagen 3 de 3
    • Pry open the back cover, starting from one side.
    • Use a lot of isopropyl alcohol to soften the glue.
    • Use cotton pads to spread the isoprop under the screen.
    Pregunta a FixBot
    Agregar Comentario
  11. PocketBook Verse PB629 Screen Replacement, Remove the screen from the frame: paso 11, imagen 1 de 3 PocketBook Verse PB629 Screen Replacement, Remove the screen from the frame: paso 11, imagen 2 de 3 PocketBook Verse PB629 Screen Replacement, Remove the screen from the frame: paso 11, imagen 3 de 3
    • Use isoprop to loosen the glue between screen and frame.
    • Push from the front to get the screen out.
    Pregunta a FixBot
    Agregar Comentario
  12. PocketBook Verse PB629 Screen Replacement, Replacement parts: paso 12, imagen 1 de 1
    • Search for replacement parts with following properties:
    • Suitable for Pocketbook verse PB692
    • Screen ED060XCG,ED060XCH or similar
    • Three flexcables!!! (only two and the touch or the backlight will not work)
    • The small flexcable on the right, for touchscreen has to read FT6336U as other protocols will also not work.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
LStrong
Miembro Desde 09/12/25
445 Reputación
3 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 35
Ultimos 30 días: 152
Todo El Tiempo: 913
