Saltar al contenido principal
Plum Optimax 10 Motherboard Replacement
Qué necesitas
  1. Plum Optimax 10 Motherboard Replacement, Back Cover: paso 1, imagen 1 de 2 Plum Optimax 10 Motherboard Replacement, Back Cover: paso 1, imagen 2 de 2
    • Use a metal spudger to remove the small panels to the immediate left and right side of the camera.
  2. Plum Optimax 10 Motherboard Replacement: paso 2, imagen 1 de 2 Plum Optimax 10 Motherboard Replacement: paso 2, imagen 2 de 2
    • Use a metal spudger to begin lifting the back cover.
    • Then, create leverage and gently remove the entire cover.
  3. Plum Optimax 10 Motherboard Replacement, Motherboard: paso 3, imagen 1 de 2 Plum Optimax 10 Motherboard Replacement, Motherboard: paso 3, imagen 2 de 2
    • Use flathead screwdriver tool to remove the three 2.5 mm screws shown in the photo. Two screws are located at the base of the motherboard and there is one screw located at the top.
  4. Plum Optimax 10 Motherboard Replacement: paso 4, imagen 1 de 1
    • Once screws are removed, carefully remove the motherboard out of encasing.
Conclusión
Una persona más ha completado esta guía.
Samantha Wright
Miembro Desde 11/06/18
243 Reputación
2 Guías creadas
Equipo
IUPUI, Team S1-G4, Hovde Fall 2018 Miembro de IUPUI, Team S1-G4, Hovde Fall 2018
IUPUI-HOVDE-F18S1G4
3 Miembros
6 Guías creadas
Un comentario
This document is incomplete. It does not detail removing the cables connected to the motherboard.
Before the motherboard can be removed from the case, the Digitizer, the LCD and the power and camera cables must also be removed. the speakers, vibrator and Mic can come out with the motherboard.
George Earl Martin - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 162
