Saltar al contenido principal
Plum Optimax 10 Headphone Jack Replacement
Qué necesitas
  1. Plum Optimax 10 Headphone Jack  Replacement, Back Cover: paso 1, imagen 1 de 2 Plum Optimax 10 Headphone Jack  Replacement, Back Cover: paso 1, imagen 2 de 2
    • Use a metal spudger to remove the small panels to the immediate left and right side of the camera.
  2. Plum Optimax 10 Headphone Jack  Replacement: paso 2, imagen 1 de 2 Plum Optimax 10 Headphone Jack  Replacement: paso 2, imagen 2 de 2
    • Use a metal spudger to begin lifting the back cover.
    • Then, create leverage and gently remove the entire cover.
  3. Plum Optimax 10 Headphone Jack  Replacement, Headphone Jack: paso 3, imagen 1 de 3 Plum Optimax 10 Headphone Jack  Replacement, Headphone Jack: paso 3, imagen 2 de 3 Plum Optimax 10 Headphone Jack  Replacement, Headphone Jack: paso 3, imagen 3 de 3
    • Disconnect the ribbon cable connecting the headphone jack on the motherboard by lifting up on the black press fit connector with a plastic opening tool.
    • Use a plastic opening tool to pry up the headphone jack from its place in the case.
    • The headphone jack is lightly adhered to the back case.
    • When removing the jack, be gentle with the ribbon wire because it is capable of tearing.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 87
