Introducción
This guide explains how to take apart the Sony PlayStation 3 optical drive. These steps are useful for repairing or replacing the optical drive.
Qué necesitas
Flip over the optical drive enclosure. There are four ribbon cables connected to the circuit board. Using a spudger or your finger, lift each ribbon cable latch and disconnect each ribbon cable.
Remove the three screws on the board with a Phillips #00 screwdriver.
Remove the two silver screws on the bottom of the case. These screws are different from the ones on the board and should be kept separate.
Flip over the enclosure so that the circuit board is on the bottom and the optical sensor is on top.
Remove the screw on the optical sensor using a Phillips #00 screwdriver.
Remove the tape on the red and black wires that connect to the optical sensor. With the wires still attached, take the sensor off the ensclosure.
Remove the four black screws on the edges of the enclosure using a Phillips #00 screwdriver.
2 personas más completaron esta guía.
Un comentario
When reassembling it there is a key part that needs to be exactly inline. see this video for help: http://www.youtube.com/watch?v=hzHPRGHFj...
