Saltar al contenido principal
Playstation 3 Motherboard Replacement
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
  1. Playstation 3 Motherboard Replacement, Top Cover: paso 1, imagen 1 de 2 Playstation 3 Motherboard Replacement, Top Cover: paso 1, imagen 2 de 2
    • Remove the rubber screw cover near the hard drive cover with a spudger.
  2. Playstation 3 Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove the screw holding the top cover in place with a Torx T10 screwdriver.
  3. Playstation 3 Motherboard Replacement: paso 3, imagen 1 de 2 Playstation 3 Motherboard Replacement: paso 3, imagen 2 de 2
    • Slide the top cover down about half an inch.
    • Lift the cover off of the PS3.
  4. Playstation 3 Motherboard Replacement: paso 4, imagen 1 de 2 Playstation 3 Motherboard Replacement: paso 4, imagen 2 de 2
    • Remove the seven screws in the top cover with a Phillips #2 screwdriver.
    • One of the screws is shorter than the others. The short screw is marked in yellow.
  5. Playstation 3 Motherboard Replacement: paso 5, imagen 1 de 3 Playstation 3 Motherboard Replacement: paso 5, imagen 2 de 3 Playstation 3 Motherboard Replacement: paso 5, imagen 3 de 3
    • You can now lift off the top cover.
  6. Playstation 3 Motherboard Replacement, Power Supply: paso 6, imagen 1 de 2 Playstation 3 Motherboard Replacement, Power Supply: paso 6, imagen 2 de 2
    • Unplug the white wires connected to the wireless board. There are two sets of wires: one set in the front, one in the back.
    • Push down the tab on the connector to disconnect the wires.
    • Remove the two screws on the front of the power supply.
  7. Playstation 3 Motherboard Replacement: paso 7, imagen 1 de 1
    • Remove the screws on the back of the power supply with a Phillips #2 screwdriver.
  8. Playstation 3 Motherboard Replacement: paso 8, imagen 1 de 2 Playstation 3 Motherboard Replacement: paso 8, imagen 2 de 2
    • Remove the power supply by lifting it straight up.
  9. Playstation 3 Motherboard Replacement, Motherboard Enclosure: paso 9, imagen 1 de 2 Playstation 3 Motherboard Replacement, Motherboard Enclosure: paso 9, imagen 2 de 2
    • Unplug the optical drive power cable.
    • Detach the ribbon cable that connects the optical drive to the motherboard.
    • Set the optical drive aside.
  10. Playstation 3 Motherboard Replacement: paso 10, imagen 1 de 2 Playstation 3 Motherboard Replacement: paso 10, imagen 2 de 2
    • Remove three screws (Phillips #2) from the wireless board and antenna.
    • Detach the ribbon cable that connects the wireless board to the motherboard.
  11. Playstation 3 Motherboard Replacement: paso 11, imagen 1 de 1
    • Remove nine screws (Phillips #2) from the perimeter of the metal plate covering the motherboard.
  12. Playstation 3 Motherboard Replacement: paso 12, imagen 1 de 3 Playstation 3 Motherboard Replacement: paso 12, imagen 2 de 3 Playstation 3 Motherboard Replacement: paso 12, imagen 3 de 3
    • Remove the hard drive door with a spudger.
    • Lift the metal enclosure out of the plastic bottom case.
  13. Playstation 3 Motherboard Replacement, Motherboard: paso 13, imagen 1 de 2 Playstation 3 Motherboard Replacement, Motherboard: paso 13, imagen 2 de 2
    • Remove four black screws (Phillips #2) from the top plate of the motherboard enclosure.
    • The two, small plates held down by the screws should become loose. Remove these plates.
    • Remove these plates.
  14. Playstation 3 Motherboard Replacement: paso 14, imagen 1 de 1
    • Remove the large, top plate by tilting it back until it comes off.
  15. Playstation 3 Motherboard Replacement: paso 15, imagen 1 de 2 Playstation 3 Motherboard Replacement: paso 15, imagen 2 de 2
    • Slide the back panel out of the enclosure.
  16. Playstation 3 Motherboard Replacement: paso 16, imagen 1 de 3 Playstation 3 Motherboard Replacement: paso 16, imagen 2 de 3 Playstation 3 Motherboard Replacement: paso 16, imagen 3 de 3
    • Lift the motherboard to separate it from the rest of the enclosure.
    • There are two blocks on the bottom of the motherboard that stick to the metal plate with thermal paste. When reattaching the motherboard to its enclosure, make sure to put thermal paste on those blocks.
    • Detach the two ribbon cables from the motherboard.
Conclusión
3 personas más completaron esta guía.
iDeleted
Miembro Desde 07/07/10
2,101 Reputación
39 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 3,150
