Introducción
This guide shows you how to disassemble and replace the motherboard of your Playstation VR Headset.
Qué necesitas
Peel back the rubber covering around the lenses to remove the surrounding plastic eyepieces.
Pinch the small white cable connector and unplug it from the motherboard.
The microphone will be attached to the white cable connector on the bottom right of the motherboard.
Remove the two 6mm screws on the L shaped silver clip to the upper left of the motherboard using the Phillips #000 screwdriver.
Remove the one 6mm screw that is securing the silver clip on the far right side using the Phillips #000 screwdriver.
Remove the three 6mm screws from the motherboard using the Phillips #000 screwdriver.
Unplug the white cable and ribbons from the motherboard(make sure to lift the gates on the ribbons before pulling out).
Unplug the HDMI cable by lifting the gate and pulling gently(there will be adhesive).
Una persona más ha completado esta guía.
