Saltar al contenido principal
PlayStation VR Band Adjuster Replacement
Qué necesitas
  1. PlayStation VR Band Adjuster Replacement, Band Adjuster: paso 1, imagen 1 de 3 PlayStation VR Band Adjuster Replacement, Band Adjuster: paso 1, imagen 2 de 3 PlayStation VR Band Adjuster Replacement, Band Adjuster: paso 1, imagen 3 de 3
    • Use your hands to remove the foam piece in the headband.
    • Use the iFixIt Opening Tool to pry the top and bottom trim pieces off of the rear band assembly.
  2. PlayStation VR Band Adjuster Replacement: paso 2, imagen 1 de 1
    • Remove a total of four 5 mm screws from inside the left and right sides of the headband using a Phillips #00 screwdriver.
  3. PlayStation VR Band Adjuster Replacement: paso 3, imagen 1 de 2 PlayStation VR Band Adjuster Replacement: paso 3, imagen 2 de 2
    • Remove three silver 5 mm screws that are securing the rear white cover of the band using a Phillips #00 screwdriver.
  4. PlayStation VR Band Adjuster Replacement: paso 4, imagen 1 de 3 PlayStation VR Band Adjuster Replacement: paso 4, imagen 2 de 3 PlayStation VR Band Adjuster Replacement: paso 4, imagen 3 de 3
    • Remove the 6 mm screw from the retainer securing wires to the rear band assembly using a Phillips #00 screwdriver.
    • Use a spudger to flip up the retaining flap connected to the rear LEDs.
  5. PlayStation VR Band Adjuster Replacement: paso 5, imagen 1 de 1
    • Remove the single 5 mm screw from the center of the headband adjuster using a Phillips #00 screwdriver.
  6. PlayStation VR Band Adjuster Replacement: paso 6, imagen 1 de 1
    • Gently pry the adjuster assembly away from the rear headband using an opening tool.
  7. PlayStation VR Band Adjuster Replacement: paso 7, imagen 1 de 3 PlayStation VR Band Adjuster Replacement: paso 7, imagen 2 de 3 PlayStation VR Band Adjuster Replacement: paso 7, imagen 3 de 3
    • Disassemble the adjuster assembly spring, small gear, large gear, and bracket in order to replace the broken component.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 14
Ultimos 30 días: 69
Todo El Tiempo: 2,460
